Buy here
- Limit 5 per customer
- Refurbished – This means the product was tested and repaired as required to meet the standards of the refurbisher, which may or may not be the original manufacturer. Any exceptions to the condition of the item outside the manufacturer’s information should be provided in the listing, up to and including warranty details.
- Item Condition: 95% New
- Convenient Cleaning: The EufyHome app, and Amazon Alexa and the Google Assistant voice control-services let you accomplish your vacuuming needs with zero effort from you.
- Worry-Free Cleaning: Set Boundary Strips and the slim 2.85” body—upgraded to 1500Pa* suction—only cleans the areas you want.
- BoostIQ Technology: Automatically increases suction power within 1.5 seconds when extra vacuuming strength is needed—so you get the best clean in the shortest amount of time.
- A Quiet Clean: Vacuums for up to 100 minutes** of constant, powerful suction that’s no louder than a microwave.
- What You Get: RoboVac 35C, 6.6 ft Boundary Strips, remote control (2 AAA batteries included), charging base, AC power adapter, cleaning tool, extra set of high-performance filters, 4 side brushes, 5 cable ties, welcome guide, and our worry-free 3-month warranty.
