Save $50 on Anker PowerExpand Elite 13-in-1 Docking Station, Deal for $249.99
Use the $50 off Amazon Coupon
Buy here
Connect Everything Imaginable
A total of 13 ports offer unparalleled functionality. From high-speed charging to high-definition media display, ultra-fast data transfer to crystal clear audio output—PowerExpand has it all.
Fast-Charging to Multiple Devices
The 85W Thunderbolt 3 port provides enough power to fully charge a MacBook Pro 13.3ʺ in less than 2 hours, while an 18W Power Delivery USB-C port can charge an iPhone 11 in just 1.75 hours.
Transfer Files in Seconds
Dual Thunderbolt 3 ports each support data transfer at up to 40Gbps—enough to transfer a 20GB file in just over 6 seconds. SD and microSD card slots support virtually all SD card formats for seamless access to photos and other media files.
Total Multimedia Connectivity
Connect to multiple monitors via the Thunderbolt 3 and HDMI ports for a simpler and more productive experience. The Thunderbolt 3 port also supports dual 4K@60Hz displays via a USB-C to dual HDMI splitter (not included). A 3.5mm AUX port lets you listen to music or take part in meetings in full 48 kHz/16-bit digital transmission.
Model Number: A8396
PowerExpand Elite 13-in-1 Thunderbolt 3 Dock
The All-in-One Docking Station
Port Overview
On the front side (top to bottom, left to right):
-SD Card Slot (SD 4.0 UHS-II)
microSD Card Slot (SD 4.0 UHS-II)
Audio In & Out
USB-A Port (5 Gbps, 5V/1.5A)
USB-C Port (10 Gbps, 5V/0.9A)
USB-C Port (10 Gbps, 5V/3A or 9V/2A)
On the reverse side (top to bottom, left to right):
Thunderbolt 3 Downstream Port (40 Gbps, 15W)
Thunderbolt 3 Upstream Port (40 Gbps, 85W)
USB-A Port (5 Gbps, 5V/0.9A)
HDMI 2.0 Port
Gigabit Ethernet
DC-IN (20V/9A)
Dimensions and Weight
Height: 125.8 mm / 4.9 in
Width: 88.5 mm / 3.5 in
Depth: 41.9 mm / 1.6 in
Weight: 490 g / 17.3 oz
Compatible Devices
MacBook Air 2020/2019/2018, MacBook Pro 2020/2019/2018/2017/2016; XPS, Inspiron 7000, Latitude 7000/5000; EliteBook; Yoga X1/C900/C700, ThinkPad X390/T490/T590; Swift 7/5/3, Spin 7/5/3; ZenBook Pro Duo; NoteBook 9 Pro, NoteBook 9 Pen, NoteBook 9, and more.
System Requirements: The host device must support Power Delivery and DisplayPort Alt Mode or USB-C 3.1 (generation 1 or 2).
Compatible Operating Systems
macOS 10.12, Windows 8/10, iPadOS
Notes
The cable connected to your laptop must be a Thunderbolt 3 cable
