Save 34% on Anker Premium 60W 5-Port Desktop Charger with One 30W Power Delivery Port, Deal for $32.99
Great share @Shenoy
Been tempted with one of these to replace my PowerPort 5 USBA which I use for holidays.
But the low outputs of the USBA has been putting me off.
Yes it’s an old design, I’ve had one for years. The balance of ports is off, I need more C 18W+ ports. Most of us need now only s couple of A ports now.
Agree C7 corded is good for travel, sockets usually few and distant.
Had to look up C7 cord, I’m used to calling them figure if 8 cables.
Great deal!!!
In the US you can cost-effectively and compactly mix’n’match two wall chargers to get the right match of balance of port count, port type, Wattage.
The US extension cord has 2-pin sockets each side, you then place each side the Wall socket of your choice, e.g. if you wanted 4 USB-C ports you could buy two 2-ports of the 18W or 30W of your choice, or even make a 120W two 60W, or any combination from two Wall sockets.
The UK cannot, so we’re more dependent on Anker making it.
Good deal, I’m currently using mine at the headboard of my bed. Charges my wife’s iPad, my phone and her phone as well as one or two of our battery packs.
One thing is I never realized the PD port outputed 30w, guess I’m gonna have to use that more often as it will fast charge a few of my battery packs. And here I was using a different PD wall plug to charge them, now I can free up an outlet
I have one of those and have been using it daily. Great charger.
