Save 25% on Eufy RoboVac G30 – Deal for $239.99 (Save $80)
Buy here
- Smart Dynamic Navigation 2.0: With the Path Tracking Sensor, Smart Dynamic Navigation 2.0 allows for purposeful cleaning across all surfaces when compared to random path robotic vacuums
- 2000Pa of Hard-Hitting Suction: The ultra-strong 2000Pa of suction power ensures more debris is picked up across all surfaces giving you noticeably cleaner floors
- App Control with Cleaning History: Complete all your cleaning needs right from your smartphone. When the job is done check-out where and when your RoboVac cleaned
- BoostIQ Technology: Automatically increases suction power within 1.5 seconds when extra vacuuming strength is needed—so you get the best clean
- What You Get: RoboVac G30, Charging Base, AC Power Adapter, 2 Side Brushes, Additional Unibody Filter, Cleaning Tool, 5 Cable Ties, Welcome Guide, and our Worry-free 12-month Warranty
