save 23% ($60) on Nebula by Anker Prizm II + Travel carry Case Combo Deal for $199.99
Buy here
- Full HD Picture: Place in virtually any room to enhance your favorite shows or movies with a native full HD 1080p 40"-120" picture. (Recommended for use in low-light environments).
- Built-In Speaker: Dual drivers deliver balanced audio through left and right speaker grilles, pumping out a deep, immersive bass sound.
- Keystone Correction: Horizontal and vertical (±40°) adjustment ensures a clear picture from any distance or angle.
- Comprehensive Compatibility: Connect almost any device including Fire TV Stick, Chromecast, Roku, Xbox, and PS4 via HDMI or USB Lightning cable.
- Durable Design: A UL certified power supply and a 30, 000-hour LED lamp-life ensure that you can enjoy decades of worry-free entertainment.
What You Get: Nebula Prizm II, carry case, HDMI cable, power adapter, cable, remote control, user manual, worry-free 12-month warranty, and Nebula’s friendly customer service.
Model Number:D2240
Technical Specs
Brightness: 200 ANSI lm
Resolution: 1920 x 1080p
Projection Image Size: 40 - 120 inches
Display Technology: 5.2 inch LCD
Light Source: LED
Contrast Ratio: 1500 : 1
Throw Ratio: 1.4
Projection Distance: 3ft - 12ft
Projection Ratio: 30 inches at 3 ft; 60 inches at 6 ft; 80 inches at 8 ft
Keystone Correction: Horizontal and Vertical (±40°)
Audio Driver: 2 × 5W
Connectivity: HDMI 1.4, USB, AUX-Out
Recommended Operating Temperature: 14°F to 95°F
Relative Humidity: 15%–85% (non-condensing)
Power Supply: DC 19V
Power Consumption: <125W
Remote Control Batteries: 2 AAA batteries
Storage Temperature and Humidity: -4°F to 149°F, < 90% humidity
Dimensions (L × W × H): 10.98 × 10.43 × 3.81 in
Weight: 85.4 oz
Video Formats: H.264 BP/MP/HP – up to 1080p MPEG-4 SP/ASP – up to 1080p DivX 4x/5x/6x – up to 1080p H.263 P0 – WVGA VP8 – 1080p (HEVC) H.265 MP 8-bit – up to 1080p
Screw: M4
Spacing Between Screw Mountings: 5.2 × 4.6 in
Adapter: 6.3 × 3.0 × 1.0 in
*Does not support content-mirroring of copyrighted materials on Android and iOS devices.
Usage Tips:
Use in low-light environments for best results.
Not recommended for PowerPoint, Word, Excel, or business presentations.
To minimize the risk of overheating, turn off after 3-4 hours of continuous usage.
Dolby sound is not supported. If there is no sound with the picture, turn off Dolby Digital support in your Apple TV, Blu-Ray player, Fire TV, etc device.
