Samsung Wireless Fast Charger
Hi,
Can anyone advice any Fast Charge Adapter 3.0 compatible with Samsung Wireless Slim Pad fast (Model EP-P100 Fast Charger 3.0)?
The Samsung biased wireless stand, is fast charge for Samsung 10+
Was discussed recently… do a search
@MacBlank I think he’s actually asking for a charging brick
@vegagiancarlo I can recommend this charger you will just need an USB-C to USB-C cable
The two options above are both good depending on which part you are asking for
