Samsung Book2 Compatible Charger
I’m trying to find a charger compatible with the Samsung Book2. Are any of your chargers compatible with the fast charging of the Book2?
Hi can you quote a model number or link to its specs? Read it off label underneath or off packaging.
I searched and found this
https://www.samsung.com/us/mobile/tablets/galaxy-book-2/
Is that it? If so then its specs show only USB-C as its connectivity no power, so no hint so I went to its accesories page and went to the power adaptor which just says vague words like “quick charge” and 25W. As the tablet is qualcomm my best bet this is QC3 or QC4?
Anker’s equivalent of that is likely
https://www.anker.com/products/variant/powerport-1-with-quick-charge-3-0/A2013115 but its not USB-C
I suggest get a microscope to the supplied charger’s specs and photo reply here to be sure. Without precise words like “Quick Charge 3.0” or “USB Power Delivery” its possible it is a proprietary protocol.
As @nigelhealy said, it would be best to know what charging technology is incorporated, but this should cover both main methods.
https://amazon.com/dp/B0721DV7YX
The QC part on that is charger is 18W QC2, the tablet’s accessories charge is 25W so may not charge as fast. There are plenty of devices out there with USB-C which don’t work with anything other than their own chargers.
There is also a Sansumg Ativ book2 with a laptop barrel type so simply saying Samsung Book2 is not unique enough.
