Rudy Robovac 11 no light and different beep codes
Hi,
I have a robovac 11 and the device no longer has a light if I plug it in to both the charging base and directly to the device. If I plug into the device directly I get a 2-tone beep like the charging beep but not the positive confirmation final beep like it used to.
It also doesn’t activate the LED at all.
Sometimes I’ve gotten a 4 beep error code as well but again, the LED doesn’t light up.
I’ve tried disconnecting the battery but that hasn’t made a difference.
I’m wondering if this is a sign of the battery being dead or if there’s something else amiss? I’d rather buy a new battery over a new device if I can help if we the performance of the device before this was great.
Hey @David_Williams11
Have you taken a look at the charging terminals on the charging base and vacuum?
Eufys support email is support@eufylife.com
Might be running it by them for their opinion.
Keep us updated with your progress.
You could check if the battery has power.
And dont forget to also check the charging device if there is power.
