I’ve looked around quite a bit, several times, and cannot seem to find an answer!
Awhile back I discovered that the roller brush on our Robovac 11 was not spinning. Upon inspecting, it seems to me that the belt is the problem - the teeth are quite worn and the belt is certainly far smoother than it should be to engage the drive shaft gear (sorry, no pic, I don’t have it torn down right now).
I understand that these vacs are, sadly, designed to be disposable. I’m trying my best to not give in and find a solution, but I cannot find a source for a replacement ANYWHERE! And surprisingly, I have not found one discussion on this either.
So… anyone have a tip on replacement belt source?? As far as alternate solutions, I can’t think of one… kind of need the belt to make it work correctly…
