I sure hope I dont have to replace these parts THAT often … In comparison, it took 2 years for my old Roomba 680 brush to wear out. The brush guard was never replaced after 4 years of service. Even more so, the brush guard is not in stock anywhere, not even amazon (de). The filter would last at least a year before I deemed it disgusting (with a 2-week rinsing cycle). The Eufy has a “HEPA” filter which of course needs to be replaced every so often as you cannot wash it, I totally understand that. But every month seems rather excessive to me. I take it out every week and give it a good vacuum. It’s still discolored of course from trapping all the fine dust, but it still works.
Robovac Vibrating Noise
My 11S (old Willy) is about 2 years old now.
Works daily.
I had to replace nothing.
I glued one rubber lamelle (slat) of the middle brush only.
That was all.
Of course I do care about and clean it always after work.
Ah that’s good to know! All I can compare it to is my old Roomba, as I haven’t had any other robot vacuums It just seems a tad excessive changing filters every month and the main brush every 3 months. But so far I am loving the 11s, ultra quiet and cleans like an absolute boss.
You can brush this “filter” and blow out the dust from.
By brushing the filter gets perfect to hold back the dust.
(NEVER wash it!)
Works perfectly!
A little bit more care about and work, but a pensioner has really a lot of time!
Does yours have a nickname?
We have here
Astroboy, duchess, Mary and old Willy!
I give it a good vacuum/clean once a week, including the filter. I haven’t named it yet, it’s only been with us for 2 weeks now
Thanks for those that figured out the noise problem. In my case, quiet on carpet, but noisy on wood floors. After thorough cleaning didn’t help, I just swapped out the roller brush and that fixed the problem.
I actually had a spare roller brush from a filter replacement kit I ordered long ago, so I guess I’ll order another one.
There is a little wheel at the free end of the middle brush.
Put some tape around so its fixed in that open cage and try it again.
This helps often
