Bought a Robovac 30C 18months ago and have been generally pleased with the performance. However, lately one of the side brushes is slipping, the mechanism inside is noisy and grinds and the brush turns, then slips and turns then slips. Almost as if the gears inside are slipping. Of course typically the warranty is only 12 months and has now expired. Is there anything that can be done? The product should last more than 18months, warranty intact or not!
Robovac Side Brushes Noisy, Slipping and Not Turning
Unfortunately I don’t think you can order replacement parts
You can replace the defective motor easily if you have some skills.
replacements can be found and ordered at the EUFY-website.
Take a look how :
