Odd manual controls. It doesn’t turn to 90 degrees, nor 45, nor 60. It turns at a very weird angle and that makes navigation very difficult. I am forced to lift it and put it at the place I want to spot clean, or maybe another room. Cannot use the manual navigation to move it to another place due to the weird turn angle.
No edge cleaning option. Sometimes it does only a part of the house and says finished cleaning. The other day, it didnt even clean a few rooms at all, sometimes it doesnt go beyond a certain point despite no obstacles. Quite weird. But the major point of concern, no edge cleaning. Due to that I only have the option to clean the entire house again instead of just having the edges cleaned whenever it fails to clean all the edges well. On the contrary, sometimes it does edge cleaning twice and by then runs out of battery.
So this is what I would like to see fixed. The angles. Make it turn at 90 degrees. or may be 45. And please push an update to include an edge cleaning option separately along with the spot cleaning. For reference, please find “360 C50” on Amazon.in which is also at the same price point, and may be better features with the water tank as well I might say. But it does have two spot cleaning options, one spiral and one with horizontal-vertical movements. And the most important, a separate edge clean option. I hope these are taken into account and updates can be pushed ASAP.
