Has anyone gotten the RoboVac 35C to connect to WiFi using the android app yet? Using my OnePlus 8 Pro, I go through the setup process, it connects to the vacuum WiFi network but instantly disconnects because there is no real internet connection. If it does connect it crashes at 99% and says it doesn’t work.
I’ve reset the wifi on the vacuum, and I’ve retried the process a bunch of times. I also reset the cache and storage for the app. I’ve got a separate 2.4 GHz SSID. So far, no luck at all. I’ve already tried turning off BlueTooth, mobile data and used airplane mode. Any suggestions?
