Got the Roav Viva about a month ago.
Overall it is a decent device but it does have it flaws in it that can easily be dealt with easily.
Positives
It has Alexa that you can access.
It has the Power QI fast charging
It has ability to mute the speaker
App support that allowed you to easily select the radio station frequency to connect the device too.
Negative
The charging ports are on the side. This is an issue if you have a vehicle with the cigarette lighter port in recessed area. You will tend to have the cords bent more.
I have found if I am using earbuds and listening to something and come to the car, the Roav will take over the Bluetooth and disconnect me from headset. It took a few minutes to figure out what happened as I was trying to see if my soundcore earbuds (LOL) were messing up or not.
Overall it is a decent device I think Roav has a few other devices that seems to be better options.
