ROAV HydroClean, by Anker, Electric Pressure Washer Deal for $149.99 After clipping $20 Amazon coupon plus free shipping
Same product from Amazon Renewed is available for $132.99
From Roav
HydroClean
Roav by Anker Innovations is dedicated to creating connected devices for your car that improve the convenience, safety, and enjoyment of every drive.
Make outdoor cleaning easier than ever with Roav’s powerful pressure washer. Blast away accumulated grime with 2,100 psi of pressure to make your car, walkway, porch, and home look like new.
- 2,100 psi
- 1.78 gpm
- 3 Spray Nozzles
Key Features
Built-In Detergent Tank
Add detergent to your spray to add a sheen to your ride.
Easy-to-Use Spray Gun
An easy to pull hand-width trigger makes spraying a cinch.
Fully Loaded
The customizable high-pressure spray gun and a detergent tank give you everything you need to clean the way you want.
Key Features
Wash the Patio
Scour off caked-on dirt in seconds to make your patio look new again.
Clean the Car
Gently spray down your car to maintain that new car shine.
Wash the Walls
Easily remove stubborn dirt and grime to make your house the cleanest on the block.
Description
HydroClean
Higher Pressure, Deeper Clean
From Roav
Created by the same team as Anker—renowned for exceptional quality and innovation
Clean Deeper
A powerful 1800W motor forces out 1.78 gallons of water per minute for an incredible 2100 psi of pressure. Remove even deeply saturated dirt and grime in seconds.
Custom Clean
3 nozzles allow you to adjust the focus of your spray to suit any surface. Use a dispersed spray to gently clean your car, focus it to wash your house, or tighten it to scour your driveway.
Long Reach
A 35 ft long cable and 19.6 ft long hoses ensure you have enough reach to clean all around your porch, patio, driveway, or yard.
Easy Setup
Start cleaning in minutes. Simply assemble the pressure washer, connect a hose, choose a nozzle, and plug in.
Worry-Free Warranty
We have total confidence in our products and back them with a 12-month warranty. We will replace any defective product within 12 months of purchase, so use your Roav product without any worries.
Features & details
- Intense Pressure: An 1800W motor pumps out 1.78 gpm to provide 2100 psi of pressure for a deep, thorough clean.
- Premium Design: Metal handles and spray gun ensure greater durability. 3 nozzles allow you to select the way you want to clean. Note: Make certain the nozzle is securely attached before turning on the pressure washer.
- Long Reach: Equipped with a 35 ft long cable and 26 ft long hoses to clean all around your porch, patio, driveway, or yard.
- Setup in Minutes: Just assemble the pressure washer, connect a hose, select a nozzle, and plug in to start cleaning right away.
- What’s in the Box: HydroClean pressure washer, 3 spray nozzles, high-pressure hose, detergent tank, spray gun, extender wand, 12-month worry-free warranty, and our friendly customer service.
