Bought Roav Dashcam C2 Pro - upgrades from Dashcam C1. Want to remove the mount from windshield which attaches with the 3M sticker, it’s pretty hard / sticks very strong to windshield glass, and replace it with auction mount for C2 Pro.
Is there a way to remove the mount without damage to the mount or windshield
Please let me know, thanks!
or glass, will try the Windex option
you can give your windshield a nice cleaning since you are at it
