Over the last few days my Roav Bolt has gotten more difficult to pair and connect to my Note 8. Normally all I have to do is unplug the bolt and it would pair up or manually pair through settings.
Then this afternoon it stopped completely pairing. I tried unpairing and repairing. It now asks for a password to pair. the two suggested options don’t work.
I tried following reset instructions I found for a similar issue and I can’t figure out how to remove the device from Google Assistant. From what I can tell it may not even be listed in the assistant anymore.
Before I contact support I thought I would ask here. How do I do a full factory reset and if I need to do a firmware update how do I go about doing that.
