Life p2
Now while I shared my original review on Instagram and soundcore, I have a new set, and things I’ve noticed a couple things, after a couple plus months of using.
I won’t be covering standard review stuff, as done that already (see my stuff on Instagram www.instagram.com/MacBlank )
Now while these are the original pics, new ones arent needed.
UPDATED REVIEW.
Fiddly
I find removing the buds from the case fiddly.
The STRONG MAGNETS that hold them in place, are for my old arthritic fingers, fiddly to remove. You’ve got to really get you finger/finger nail, right under them to get them out, and sometimes they fall back in place before getting them out, so need a second or third attempt.
Standby.
the standby is AMAZING . No really they are. I went at least 5 weeks in between charging them, and even when I went to use on the 5th week, I had… Battery high, message in my ear when I placed them.
So if you’re the type to casually listen to music with buds, these are definitely for you. Chuck them in your bag, and just pull out when you want to (I only went 5/6 weeks).
Bluetooth
Due to the way they load to your phone (left n right separately) they really don’t care if you use just one at a time. If using just one, and you decide you want both… It’s seemless, apart from initial message about battery.
Farting Bass.
While listening to “normal” music, and flat EQ, I found on higher volume (approx 75%) they’d fart (distort). It wasn’t particularly bass heavy, as listening to Michael Ball and Alfie Boe, together n together again. No electronic bass or drums were/are used in the albums., Just live analogue drums.
So watch out for bassy tunes to bottom out and distort at higher volumes.
Auto Pause.
Nope! They won’t pause if you remove the buds from your ears, but don’t place in the case.
Either stop the sound (single push on either bud) or.okace back in the case to stop.
Do I recommend… HELL YES.
you will not get this quality, sound, standby, charge, and Anker lifetime support, anywhere for this money.
