5/5 stars
What a useful Bluetooth transmitter and reciver. This little beauty allows me to connect two devices simultaneously to play audio to for example headphones or bluetooth speakers or play music from my phone over my large speakers through my amplifier via the optical audio ports with amazing audio quality and a very stable connection.
Examples of use include Connecting to Eufy genie, television, computer, wired or wireless headphones and amplifier.
This little guy measurs in at just under 3" and about the thickness of a dvd case. It is a lot more compact and a lot lighter than I was expecting. I will most likely leave this connected to my television for late night TV viewing but it has a built-in battery and battery life of 20 hours that coupled with a wide variety of audio jack connections a adapters (rca, optical and headphone jack connecters ) make it very versatile. I have also used this to connect my wired high quality headphones with amazing results and will provide a portable headphone jack to those of you who might have lost that feature with the recent trend of cell phone manufacturers removing there headphone jacks. As I previously stated it is highly versatile the uses are only limited by you creativity and Imagination. The Setup process is fairly straightforward and detailed in the manual. But mostly consist of 2 second presses of the single button on the device and adjusting it from receiver to transceiver modes via the sliding switch on the side. As far as I can tell this is the only RX / TX with Bluetooth 5.0 and aptX audio enhancement tech putting it in a class of it’s own.
Please share your ideas for potential use below thanks for reading.
