Review - my first anker difusser (Anker 100ml Essential Oil Diffuser)
My first anker Diffuser was the Anker 100ml Essential Oil Diffuser for Aromatherapy (it is no longer available)…
Since i didn’t know what to expect, i got a small diffuser (as you can see from my previous posts, i ended up getting a 2nd one - the larger 500ml).
This is a great starter diffuser, if you dont’ know anything about oils or diffusing. it has all the functionality as the larger one, except the smaller water holder (100ml). Essentially, you have to refill this after every use. When adding in the oils, be weary on how much you put in as well, as the recommended dosage for such a smaller diffuser is only 1-2 drops. it may not seem like a lot, but it definitely does the job.
I have this one in my kids room and even though it is supposed to help you with aromatherapy, i kinda use it to ‘difuse’ the stink in their rooms! you know kids…they are always messy and keep forgetting to put their dirty clothes away, or hang up their wet towels…
This small diffuser is able to handle a good 150 square foot room without any issues and makes the room smell nice and fresh (sorta like those febreeze commercials)
Like its larger model, it has the ability to show various calming colors, and has the auto shut off as well. The other great thing about this model is that it has a 30 second delay before shooting the next mist shot. it is very quiet, and is able to fit in small areas!
A strong recommendation if you are able to get your hands on one of these for the baby’s room (helps get rid of the diaper smell), or for a kids room (they will enjoy the switching of the lights and it will help make their rooms smell better).
