Premium Quality at Low Cost!
The iPhone 7 Plus is a stunning device inside and out, so I did not want to settle for anything less than high quality when selecting a case and screen protector for the phone. Unfortunately, high quality often means high price, but that is not the case with Anker products. I was excited to see that Anker made an iPhone 7 Plus tempered glass screen protector, so I immediately jumped at the opportunity to get one. I am a big fan of the quality, look and feel that tempered glass screen protectors provide and, based on past experiences with Anker products, I was confident that this screen protector would be a good choice.
Upon opening the box, you will find that the two screen protectors are well-packaged and protected. I like that there are instructions on how to apply the screen protector, which helped me effectively and efficiently apply the screen protector. I would highly recommend following the instructions to lower the probability of getting bubbles or dust underneath the screen protector. I can hardly tell that I have a screen protector on my phone because it is clear and smooth like the actual screen. In my opinion, this is one of the best screen protectors you can get, and it is nice that you get two with your purchase! I am very happy with this product.
Thanks for reading!
Kelby
