I’ve been aware of Anker’s sister brand Eufy for sometime, which focuses on health and lifestyle products, yet I have not been able to find a product that I both required and that would not empty my wallet at the same time (sorry RoboVac). Luckily thanks to a recent 20% sale and an interest in learning more about my health, the BodySense Smart Scale has graced my doorstep. Robust build quality with sleek-stylish two tone glass and plastic construction should give years of use and fit any surrounding.
Now I’ve had or used various scales in the past, from digital back to the more old fashioned mechanical (yep the spinning wheel ones) but this is my first “smart” scale, which besides the usual weightage given, also gives a more in depth breakdown of your body composition (BC) thanks to 2 pairs of built-in sensors which cover;
Weight, Body Fat, BMI, Water, Muscle, Bone, BMR, Visceral Fat, Lean Body Mass, Body Fat Mass, Bone Mass and Muscle Mass
So for those of you like me, that were curious as to your fat vs muscle percentage but didn’t have the foggiest how to go about it, problem sorted.
Setup and Use
Once out of the box and the included 4AAA batteries are in place, the scale is good to go for measuring your weight. Depending on your location (or just unit preference) you can set the weight measurement to be shown in kilograms, pounds or stones via a push button no the rear of the scale (plus customisation in the app for recorded data). The more than adequate bright LED display will, however, only display a conventional weight measurement. If you are wanting to make full use of the scale’s features, some additional setup is required.
Firstly you will need to download the ‘EufyLife’ app from your relevant Appstore (Apple iOS 8+ and Android 4.3+ supported), complete a quick registration via the app and then enter some basic personal stat’s which will be used in conjunction with the scale to determine how your BC results add up. Once you’ve setup the app and turned on your device’s Bluetooth connection, the scale will be detected and pair from within the app automatically (don’t try via the bluetooth menu). The scale and app support up to 16 different users (large families sorted) which can either be on the same device or separate.
Note: for body composition (BC) measurements to be taken you must be barefoot, socks are fine for just weight but skin contact is required for ‘smart features’. Results can vary depending on factors such as recent exercise, alcohol consumption etc. Manual gives a full list.
Once your good to go app and battery wise, simply step on the scale and view your weight live in the app which is followed by your BC shortly after (about 5-10 seconds). The results are easy to understand for any age or tech level thanks to a intuitive colour system of blue (low), green (normal), yellow (high) based from your statistics entered (red also present on overall weight to indicate excessive). Values and/or percentages (depending on the measurement) of your BC are also provided for those who want more than just a quick reference result. Expanding each measurement in the app gives a short description to help you better understand what the measurement actually relates to. Data that is collected can be easily shared with other supported health apps such as Apple Health, to keep your health data in a single location but my preference so far as been for Eufy’s own offering for trend tracking.
Pro’s
Out of the box ready (apart from inserting batteries)
Quick BT connection and user friendly app
Accurate, when tested against two other digital scales (thanks to my parents for loaning me theirs)
App prompts if a vast difference in current and last weight measurement is detected
Sleek, modern finish that will fit any bathroom
Clear LCD display
Accurate weight measurement (compared to two other non-smart digital scales)
Re-calibration function
15 month hardware and lifetime technical support
Con’s
Scale does not play well on short pile carpets or bathroom mats, which other digital scales have no issues with. Weight measurements can be impaired by several pounds but app does warn about the drastic change in weight when this happens.
For my first smart scale I’m very impressed, not only at being able to visually track how my progress in the gym is translating on the scales but at the build quality of the scale and how intuitive and easy to use the app is. Yes they are a couple of models on Amazon which are a tad cheaper but having no experience with the brands I would find it hard to recommend them.
Will certainly be keeping my eyes open for future Eufy products as or if they make it to the UK.
