I recently bought an Anker USB 3.0 7-Port hub from Amazon, as my current laptop only had 2 available USB ports on them. (we used 1 for the wireless mouse, and the other to hardwire to our printer). However, if you wanted to load anything else on to it, you were very limited…
that brought me to this hub. I did some extensive research on HUBs out on the market, and knowing that Anker has been known for their great products, i opted for this one. It allows for 7 additional USB ports on it, including a high speed port that allows me to transfer data from my phone to my laptop quickly and easily.
The hub is very compact (small enough to fit in my hand), and is made out of a strong material (dropped it by accident , and it survived the fall, without any dents or breaking it)
I didn’t need to install any additional software to use this either, as some of the other models on the market required, so i was happy to see that.
Overall, this product has been useful allowing my laptop to access more USB Ports.
https://smile.amazon.com/dp/B014ZQ07NE/ref=cm_cr_ryp_prd_ttl_sol_8
