Review - Anker 500ml Essential Oil Diffuser for Aromatherapy
So, I got into the craze, like everyone else, by purchasing an Oil Diffuser. A lot of my colleagues at work swear by these, and that the oils that you use will make you feel better.
This oil diffuser is so much different than most on the market.
First of all, the price that you are paying for this is way less expensive than most on the market of equal size.
2) It offers some really cool light features (can leave as a solid color, or rotate between colors, illuminating your room
3) It has an auto shut off feature, so that you do not have to run it all night long and waste electricity.
4) it has 2 settings - high and low - allowing a large amount of mist to be released, or just a little at a time.
5) it is 500ml - which is HUGE!!! you don’t have to fill up the water as often, and when you are using different oils, you can put a lot more drops
Overall, this product allows you to spread your wonderful aromatherapy throughout a large room (at least 500 square feet). With the large capacity, it makes it much easier to “set it and forget it”. (i run it for 3 hours a night and refill it once a week)
if you don’t want to use it for the oils, you can use it as a humidifier, and just let the mist ease out throughout the night…but for me, i enjoy the different oils.
https://smile.amazon.com/dp/B01B2PDJEK/ref=cm_cr_ryp_prd_ttl_sol_21
Nice product, I bought 2 and it’s working great
