Replacement Cord
Where can I buy the cord that is used to charge the Anker - PowerCore 20,000 mAh Portable Charger? I’ve lost
it and cannot figure out how to buy it from the Anker website?
If you can’t figure out how to buy it from the Anker store you’re best bet is to grab one from Anker Direct on Amazon.
I believe that model has a standard micro-USB cable to charge the device. All you need is any of the Anker Micro-USB cables to charge it. Get from Anker.com or from Anker Direct on Amazon.
Ditto to what @Macgyver15 & @Element321 both said. Plus if you have any other Anker products, then you probably have another micro-USB cable around.
Anker products are also available at Walmart Bestbuy and Costco just make sure you purchase your Anker products from an authorized dealer to ensure genuine Anker products.
