I would like to know how I can get a replacement clip like the one in the second picture on the bottom.
Greg
Greg
What happened to the one you got with the headphones?
If it broke during NORMAL USE turn email… support@anker.com
Quoting order number, where n when you purchased and how it broke and serial number (found on the tag on the headphone cable).
** * * ** If broke due to misuse, or more than 18 months ago, then it’s not covered and you’ll have to buy as per above.
Thank you both. I lost it on a trail run sometime during the day and I just couldn’t find anything on where to buy that one piece. I appreciate the responses.
If you know anyone with a Sony Experia, they usually come with a clip.
