Renting Moves on Mars 2 Pro
Hello,
Has anybody figured out how to rent a movie on the Mars 2 Pro. I tried to rent via itunes or google play, but both failed to cast to the Mars 2. I can use a chromecast, but I’ve heard/had issues with audio syncronization issues and some choppiness.
Thanks
Thanks for your inquiry.
Please be noted that copyrighted content won’t be cast on Mars 2 Pro. You will need to use HDMI connection. The HDMI lag should be less than 30 ms.
Sorry if any inconvenience caused. Thanks for your understanding and support!
Anker Support Team
Thank you. Can you suggest an app that I can use on the Android TV to rent movies? Also, when will google play services be supported so I can rent from google play directly from the device and not require an hdmi connection
