Recommended powerbank for macbook pro 13in 2017
Team
what is the recommended powerbank for macbookpro 2017 wirh USB-c
This one gives 30w via USB C. I’ve not got a MacBook so not fully aware of what it needs but this will certainly stop it running down so quickly.
Others will jump on soon with better advice :thumbsup:
Anker PowerCore+ 26800 PD, USB-C Portable Charger with Power Delivery, Type-C Port With Fast-Charge Input and 30W Output for iPhone X / 8 / 8 plus / MacBooks with Type-C
The 2017 MacBook Pro comes with a 85W wall charger for fast charging. As @Oggyboy has mentioned you can use a PowerCore 26800+ PD to recharge at 30W but charging would be much slower than using the supplied wall charger, even in a powered off state, due to the 55W difference.
