Recent purchase of Anker 10050 PowerCore+
Hello…just purchased the Anker 10050 PowerCore +, and I am wondering, do I need to fully charge this first, or is it ready to go? Right out of the box, it shows 4 of the light indicators solid…do I want to fully charge it so that all the lights are showing solid before first use?
Thanks!
Ready to go :wink:
Yes, you can use it now. If you’re going to use it soon, it won’t hurt to fully charge it either.
If you’re not going to use the power bank for several weeks, it’s best to leave it with a partial charge (like between 50-75%).
I would recommend fully charging it.
