Hello, I would like to know if this model: Quick Charge 3.0 39W Dual USB Car Charger can be used to charge the Galaxy A5 2016.
Is it compatible?
Thank you
Is it compatible?
Thank you
A quick search indicates that phone is 5V 2A so nearly everything Anker sells is as powerful as the phone can ingest. What you’re going to get is compatibility, yes, but you’re paying more for Quickcharge 3.0 when your phone does not have Quickcharge 3.0
You’d be saving money to buy a non-QC car charger.
Such as this
Thank you nigelhealy, I’ll get this one in which you indicated !!! Thank you so much
