Questions on the new Solar and Vega projectors
I’m debating on getting a regular or portable Solar/Vega. I usually won’t be using this outside away from outlets but I think it’d be nice to be able to run it wirelessly but am not sure if it’s worth the extra cost.
I’m also wondering about the size. Is there a size difference with the “portable” name or does that just mean there is a battery in it?
Thanks!
I think regular one will be better… But acc to me it might be cool if you have anker powerhouse + projector. In that case you will be in safe side i think. Power will not be problem then.
Solar is just a name…the projector doesn’t actually use solar sun power :joy: that’d be cool though!
I’d edit that away, you’ll never live it down.
The projectors have an Astronomical theme. Nebula, Cosmos, Astro, Mars, Solar, Vega, Capsule
Solar has two flavours, one with a battery Solar Portable.
