Question for Zolo earbuds
Does anyone know if we can use just the one earbud and leave the other in the charging box? I have the Zolo Liberty ear buds.
You Can use the right earbud by itself. The left earbud cannot be used by itself.
Let me know if you have any further questions!
Thank you, darn I use the left and have my work headset on my right ear, might have to try working with the headset on the other ear.
Im sure you can only use one of them by its self. This is only because of the other earphone needs to be connected to the other one in order to get a sound across.
It depends on which version of the liberty you have. If you have the updated version then yes you can pair the left earbud to your phone for use individually, but beware that you will lose the left and right sync. In order to get it back you would have to reset both earbuds which is a process in itself
yes, but choose the right side.
