Question about Qualcomm Quick Charge 3.0 Ports on Anker products
Please Help!!! I have been searching everywhere and I cant seem to get a straight nor consistent answer.
Is it SAFE and possible to charge Non-Quick Charge divices into a Qualcomm Quick Charge 3.0 port without causing damage to the device? Examples would be Gopro Hero 5, battery chargers, and iPhone 5s. I want to get a Quick Charge charger to have the flexibility to charge my Non-Quick Charge devices as well as any future products i buy in the future that do support Quick Charge. I know that i will not reap the advantages of the quick charge but i would like the flexability to charge Quick Charge and Non-Quick Charge devices off of the same charger safely without damaging the device.
Yes. The device itself will “Pull” the voltage/amperage that it requires. The power adapter doesn’t “push” power through.
Yes, as @tommcd24 said your devices will only pull the maximum voltage/amperage that they can.
