Qualcomm Quick 2.0 vs Qualcomm Quick 3.0
Hi everyone,
I wish to buy the Anker powercore+ 26800 but I noticed differences between 2 products on amazon:
1 . Anker PowerCore+ 26800 Premium Portable Charger High Capacity External Battery with Qualcomm Quick Charge 3.0 and PowerPort+ 1 with Quick Charge 3.0 Wall Charger.
You can find it on Anker.com under USB Chargers, and it links to amazon.
unfortunately, the product is Currently unavailable.
2 . Anker PowerCore+ 26800 Power Bank with Qualcomm Quick 2.0 and PowerPort+ 1 with Quick Charge 3.0 Wall Charger.
You can find it on amazon thru Anker store.
I wish to know if the two are identical (because the second one does not even appear in Anker.com), and if not, what is the difference between them?
Respectfully,
Etay
Different vintages. QC3 s nwer faster but needs a QC device.
Is your device QC2 or QC3?
What is the price difference?
I didn’t buy my device yet.
I’ve tried to buy the QC3 but it ran out from stock and now I find only QC2.
10$ difference.
if I use QC3 with Iphone 6s(to my understanding does not include QC chipset), how fast will it be charged?
Get the speed one.
Consider going smaller there’s a 10000mah speed one.
The claims are it will drive to the fastest possible.
Please explain.
I didn’t understand which one you recommend me to buy and why.
which one is the “speed one”?
And why should he be faster than the two I’ve asked about?
Anker release products different times in different countries (usually USA) first. The “Speed” series is all of their, well, speedier charging combined. If it is actually any faster for you - don’t know, go find a review.
Thanks a lot :slight_smile:
Are you looking at these two??
https://www.amazon.com/gp/product/B016HNALOI
https://www.amazon.com/Anker-PowerCore-Portable-Capacity-PowerPort/dp/B01K6TA748
You mention you have an iPhone… iPhones and iPads do not support QuickCharge at all… so support of QC2/QC3 on the output USB ports for your device wont matter.
Where it could help you is to recharge the PowerCore itself, if the PowerCore you are looking at supports it (sometimes Anker will call these RapidRecharge). This will help it charger the PowerCore at a faster rate with a compatible wall charger (usually a QC2/3 wall charger)
