I’ve had the exact same difficulty trying to charge my C1000 off the 120v outlet in my F 350. The outlet has a 400 watt max output so I set the charge rate at 200 watts on the Anker app and only get clicking from the Anker battery when I plug it into this outlet. I’ve sent multiple emails via the Anker help desk only to get back computer generated responses for other Anker products that I don’t own. So far, their customer service gets a big fat “0” from me! I’m about to try a different inverter in my truck besides the one that came with the vehicle since the problem might be dirty 120v power (ie: a chopped off sine-wave instead of a smooth one). I hate chasing this problem when there’s probably an Anker engineer who can better direct me before I spend time and money that may or may not solve the problem. I hope I don’t regret this C1000 purchase. The unit has had the DC port shut off when using my camp fridge despite me telling it to never shut off. The unit charges at 110watts in my trucks DC power port but that’s 10 hours of driving for a full charge! Ugh…
Q&A Session with PMs on the SOLIX C1000
Hi, Is there feature in the Anker app if I can schedule to power on/off the AC input or solar input ?
Why i can’t add Home Energy System with C1000?
Hi, I have a C1000x that I am using with an ANKER 400w solar panel which works well, but my question is, if I buy another ANKER 400w solar panel potential generating 800watts on a very good day, but the C1000x only supports 600w input, will it still work but just limited my max input to 600watts? It won’t harm it in any way if I have a rare beautiful day generating 800watts
Thanks in advance
Mark
For areas with unstable power network:
- what is the input voltage range (for 110v and 230v versions) for the AC charging to be possible
- what are the voltage thresholds for switching from bypass to inverter mode?
Is it possible to activate eg. switch on my Solix C1000 while off grid?
For instance switch on the inverter for a couple of hours using WiFi while away from home.
Currently use a 110 generator hooked to my breaker box through 220, yes have back feed protection.
The cord for the generator has a cross over to provide 110 to both legs. I turn on breakers for room/device I want. Works perfect.
Plan to hook my new C-1000 up same way, but question is since it is going through breaker panel, do I use one std AC outlet to breaker box, or do I use Surge Pad? Since feeding home all sorts of devices will be run, but not simultaneously like fridge, TV, laptops, cell phones, tablets… basically everyting.
How do I turn the Solix C1000 on remotely using my cellphone? Scenario: I am away from my camper on a bicycle adventure. The fridge doesn’t recycle for a long time, fooling the Solix into turning off. I know it is off because I cannot connect with my cellphone. All of my food spoils. How do I prevent this from happening, or how do I turn the Solix on remotely?
Howdy. Firstly, if a refrigerator or freezer is closed, it is typically more efficient to just allow them to cycle as needed. Meaning, it usually takes less energy to maintain the temperature than to force it to recovery 5-10 degrees by trying to manage this manually.
However, to answer your question.
A couple of things you should do.
- Change how long your device timeout time. This will prevent it from turning off.
- You can manually turn the AC or DC(Car) output off or one.
Hi, just picked up the solix c1000. Looking to use it to recharge my ebike on a multi-day trip. Can’t use a gas generator and will have no access to power. My goal is to recharge the solix between rides from my Toyota Tundra cigarette lighter outlets. I tested this yesterday and was getting 100w of recharging power out of the truck outlet. Slow, but over several hours I assume I could get at least a partial charge between locations and could repower my bike overnight. So far so good. But I noticed after about a 15 minute test of recharging the solix from my truck outlet that the solix connector plug (and I assume my truck cigarette lighter outlet) as very hot, too hot to touch. Trying to avoid frying either my truck or the solix. Please advise. Is this normal, dangerous?
I have a c1000 for woodworking, camping and running shed AC window unit off grid. I also have a couple of LiFePo4 100ah batteries. I have built a battery box with 50amp anderson post for trolling motor. Does it make sense to hook up the lithium battery and c1000 with anderson to xt60 to charge the c1000 while running off grid AC? I was not comfortable charging c1000 using the cigarette lighter port.
