So I am predicting Anker will within the next year make a:
- Bluetooth speaker, stereo
- with a Qi 15W Wireless output coil on it’s top and/or its front.
- It is wired charger of USB-PD, probably 30W
- Contain 8000mAh-10000mAh order of size internal cell
- contain a top Qi pad, probably around 7.5W-10W
- contain a front Qi pad, probably around 15W. The phone has to be propped up in portrait mode and the speakers are either side.
- it will use the fact that sound actually moves air in/out and so it cause cooling air, and they’ll use this to help chill the front pad.
- there may have to be a small fan come on at times.
- shipping date after August.
This will be similar to the Wakey but add a front stand, have a battery so you can carry it with you.
I estimate the cost will come out in the region of $40-$45.
This would be a different emphasis to the Powerconf, you’d prop your phone up and do wireless calls and video calls using the speaker for audio.
If Anker made it would you buy it?
- I’d buy a combined BT speaker with wireless charger.
- I’d not bother, thanks for asking.
0 voters
