The holidays came early with this powerport!!
Picture this…thanksgiving evening with all your family over…and obviously, the kids (and adults now) are all looking for a charger! Taking all of those food pics for instagram kills battery pretty quick!
well, this charger is perfect for that.
I’ve attached some pictures so you guys can see, but overall it has 1 PD USB-C port, and 4 Power IQ USB ports.
The USB-C port can be used to charge phones that support it, and even macbooks or other powerbanks.
The other 4 power IQ ports are perfect for charging multiple devices all at top speed. It wont get “android quick charge” speeds, but a lot of android devices tend to be USB C now, so that PD port should be perfect.
My pros: good number of ports, great feel to the charger itself, LED on the charger isn’t too bright so have in a bedroom.
Cons: The charger comes with a permanent adhesive strip…For me personally, I’m going to skip out of the included strip, and probably just use a Command Strip or one of those velcro strips so that I can take this charger with me when I travel. Theres just too many ports not to take advantage of when traveling.
So even that con isnt really too big of a con since it’s just an option anyway.
Overall, this charger is great! I’d definitely recommend this or a similar product for anyone that always has trouble looking for an empty outlet for their charger or who travels a lot and needs to keep multiple devices charged up.
Right now, I have my charger set up behind the Sofa in the living room that’s in front of a ledge of sorts. The charger has 1 usb C cable plugged in for android phones, 1 microUSB for other androids/power banks, 2 wireless chargers plugged in for convenience, and that still leaves open a slot for a Lightning cable for an iPhone, or really anything else.
It’d be awesome if it also had Quick Charge ports on here, but I’m sure there are other products that have those instead of the USB C maybe; feel free to post them below if you have any suggestions!
This is also my first review, so let me know what to improve on, since I know theres probably a lot!
pics:
