PowerLine USB-C to USB 3.1 adapter with Apple USB Superdrive on Macbook Air M1?
Does the Anker Powerline USB-C to USB Adapter (USB 3.1 Gen 1) work to connect an Apple USB Superdrive to an Apple 2020 Macbook Air M1? I don’t have the Superdrive yet so is there any model numbers that wouldn’t work? Thanks.
This would be a question for the support.
@benlebb As it is just a data transfer cable I doubt you will have any compatibility issues but you can get confirmation from support@anker.com
