I absoloutly love the texture/feel of the PowerLine II 3-in-1 cables. I would like to order some other Anker cables made of the same materal. Do you guys know if this is PVC or TPE?
PowerLine II 3-in-1 Material
The PowerLine II 3-in-1 cable is made of Dyneema fiber. Hope it will help you make the choices.
Ahhh no it didn’t. That confused me even more. Hahahaha
Is the 1 foot lightning PVC or TPE the most similar?
It’s more similar to TPE. If you’re looking for the 1 foot lightning cable which has the same material as PowerLine II 3-in-1 cable, please check out this one.
