Hi folks. Just bought one of these awesome powerhouses and I noticed after a few weeks of fulling charging it and not using it, it’s down to 95%. Is that normal? Thanks.
Powerhouse 120000
Totally normal. The same thing happens to all batteries.
That’s what I thought. Thank you for confirming!
Self discharge is normal for batteries. Protective circuitry consumes a bit of power too. When not in use, store in liquid nitrogen, or Siberia. Kidding.
Just make sure you store in a cool place when not in use to prolong the longevity of the cells inside.
Yes its normal.
e.g. My replacement battery for the laptop:
New!
design: 42,6 Wh,
When fully charged: 41,6 Wh
Real capacity : 98,5% but fully charged : 100%
I would suggest using every once in a while and do let completely drain all the way. You don’t want to be empty when you need it.
