Powerful Small Charger
This charger is great for both iPhones + Macbook Laptops! It allows charging for both devices at the same time. If you remove one of the cables, a higher power (60w) will be supplied to the MacBook.
It’s a great piece of hardware and the build quality is also very good.
Its also very small and can fit in my backpack easily!
Very glad to hear you like your charger! Your pictures look very nice :+1:
Good review, straight to the point :thumbsup:
nice review. thanks for sharing
thanks for sharing
