Not much can be said about this 12 outlet power strip by Anker, but if you need 12 outlets, this should be your go to power strip
6 outlets series, 6 spaced-out outlets for those
Bricks
The power strip comes with a THICK wire (14 AWG) and appears to have some writing that says “300 Volts” on it, if that is helpful for anyone, length is 6ft
From the picture below, you can see that the outlets do NOT have any child protection built in that would prevent your child from sticking things into the terminals, you can see from a side by side comparison with the Anker PowerStrip 3 outlet. If you are going to use this power strip, I would assume this would not be lying around within reach of your children, so it may not be necessary…
2 indicator lights for showing dual surge protection is active and 1 indicator light for ground. The switch itself has a LED light built inside which illuminates white, pretty neat (see picture)
Overall, this feels like a very sturdy well built power strip, I decided not to test the dual surge protection… I’ll just wait for an electrical surge to happen and come back and update this review to tell you guys how well this survived… I have a JABRA AC TO DC switching adapter that started making hissing sounds when plugged in. I read that it has to do with an electrical surge that may have affected the capacitor? If anyone can confirm this is the case that would be awesome, but thankfully I have a spare… anyways I would be plugging that bad boy into a surge protector power strip like this one to avoid that happening again…
I like this. And if you have many things you need to plug into one power strip or lacking outlets, you should get it…
This is a review product, enjoy the pictures…
Thank you @AnkerOfficial
