PowerExpand 9-in-2 USB-C Media Hub - Ethernet Device in MACBook ???
Hello,
I got Amy Adapter today, but I see no new Ethernet Connection on my Mac.
is there some special ToDos to get one?
All that Thunderbolt Connections are from other Adapters and not connected @ this time.
The Ethernet Cable in the new Anker Port shows traffic and link.
i am surprised…
kind regards, gerald
Hi @Gerald_Amrhein do you get the same behaviour under another account on your MacBook (guest or secondary account for testing)?
If so it would be worth reaching out to support@anker.com with your MacBook model (inc OS revision) and the issue to see if they are aware of any compatibility reports at present.
