I recently bought the PowerExpand+ 5-in-1 USB-C Ethernet Hub and haven’t been able to get anything to work quite right.
The main reason I bought it was to be able to connect two seperate monitors to my laptop via HDMI, but whenever I plugged an HDMI cable into the hub, the monitor I plugged in had a ‘no signal’ error. I know it’s not the cables/monitors at fault because they work perfectly when plugged in directly to my laptop’s HDMI port.
Another problem I noticed when checking if it was just the HDMI issue was when plugging in a USB device (I used a USB mouse) it works perfectly and is responsive for about a minute and then suddenly the device constantly freezes and stutters. I tried looking at my USB drivers to see if that was the issue, but no luck.
Could this be an issue with my USB-C port, or is it a faulty hub?
My laptop is an MSI GP62MVR 7RFX Leopard Pro if the specs might be at fault.
I’d appreciate any advice/thoughts! Thanks!
