PowerDrive 2 Alloy Re-review
I have been using PowerDrive 2 Alloy for a week now. My initial thought when I first saw the packaging and product was that this is too small, either it will not work or it will be quite slow. To my surprise it works perfectly. We are currently on a road trip so I have been using my phone whole day. At any given time usually it’s charging my phone and another phone of my partner or an iPad. It charges all this devices quite fast and reliably. I haven’t timed it but I would say it take roughly same time as wall chargers from Anker. Compared to other products this is quite convenient. So far even after continues use for 5-6 hours it doesn’t get hot. I would recommend abc to everyone for daily commute to a long road trip perfect device for in car charging.
I’m glad to hear that you are enjoying the PowerDrive 2 Alloy. Thank you for the feedback on it. Do you have any pictures to show it in use? :slight_smile:
Great charger by Anker :+1:
Thanks for sharing your experiences with the PowerDrive 2 Alloy @pujan14 :+1:
Glad to know you liked it. I loved it in my car for the form factor, you don’t even know it’s and external accessory, pretty much blends in with the interior trim as a part of it :grinning:
Thanks for sharing your review :+1:
@pujan14
Mabey some pictures and spacing out but otherwise a good review
Thanks for sharing :ok_hand:
nice fit charger, Thanks for sharing!
