PowerCore Slim 10000 - what is trickle charge output voltage/current?
I see full charge rate output from the PowerCore Slim 10000 is 5V – 2.4A. What is the output for trickle charge mode? I don’t see it specified anywhere.
Thanks!
If you dont get an answer here you can ask the support.
I am sure they know.
It’s the same max output and same voltage.
What is different is the minimum current before it turns off is lower. We don’t know that lower figure but it would have to be just a few mA.
Ah ,yes. That makes sense. Thanks.
