PowerCore Metro 20000 PD Bundle
Hello i can not find my Owner’s manual and i just wanted to double check on how to use trickle charging mode for low-power devices…
I think for trickle mode use
once i plug it in, do i need to double tap, then wen the light turns Green, its in Trickle charge Mode?
Yes @Danny_R1 that’s correct.
When the light is green you’re in trickle mode :+1:t2:
Yes like Paul said the green light implies that it is in trickle charge mode which is great for things like headphones and such that have smaller batteries and can take great advantage of this.
@AnkerOfficial is there a reason the metro doesn’t have the pdf version of the owner’s manual on the website. I know others have the pdf version there for people to easily access.
Odd isn’t it @ktkundy
I couldn’t find it previously when I’ve looked for someone else.
Even if they just linked to the Essential 20000 PD that would suffice.
Here’s the Metro Essential 20000 PD version, from Anker Japan:
So the manual implies a double press or a holding of the power button for two seconds to go into trick charge mode when the great light turns on then plug in and when done press the power button again to stop trickle charge
