Hi there I bought the PowerCore ii 10000 about a month ago I charged it fully (all lights were blue) then tested it on my iPad to check that it worked and all was good. I have just tried it again and it’s not charging any of my devices. If I press the power (?!) button none of the lights come on and if I plug the PowerCore in to an adapter it doesn’t seem to charge up. I have left it about and hour so far and no lights are showing yet.
Any suggestions would be gratefully received
Cheers
Dave
PowerCore ii 10000 no lights and not charging
For a reset connect the in- and the output with the added cable for 10 seconds.
If you charge it after that procedure : DO NOT press ANY buttons.
If all these doesn’t help, you should contact
support@Anker.com
