I just purchased this 10 ft cable today. Is it any good? Does anyone have any regrets buying?
PowerCore+ II (10 Ft)
I don’t have a 10 foot, but I do have the 6 foot version (and the 3’ cable). No regrets at all. For me, the 6’ length is perfect. I’ve used several different cables over the years, and the PowerLine+ II are have been the best of the bunch.
I have the 10ft version of this in white and have been using it frequently since April ‘17 for when I’m watching content on my iPad and I’m a distance away from the mains socket.
The build and quality of the cable is second to none. You’ll never have any regrets buying an Anker cable because if something goes wrong with it within the 18 month warranty they’ll send you a replacement free of charge.
10 footers are great when you need a plug more than 6 ft away from your ideal spot. I have a few and have not regretted the purchase yet.
If I’m not mistaken I believe the Powerline+ II comes with a lifetime warranty
You’re spot on @Jesse_Hernandez1 I totally forgot about that
Hey, Even a broken clock is right twice a day
