PowerCore Fusion 2-in-1
Question:
With Anker’s PowerCore Fusion 2-in-1: can the PD port be used to charge an iPad via USB-C in Charger Mode (i.e. connected to the wall), since it’s 30 MW and the iPad comes with an 18W USB-C Power Adapter? Does this pose any problem for the iPad?
Thanks.
No, it should not. The fact that it can deliver 30W not 30MW <—That’s a lot. The iPad should charge no problem.
Hi @carpi, welcome to the Anker Community!
No, the 30W port would not cause any problems with the iPad and would actually charge it a bit faster.
Hope this helps! :slight_smile:
it would actually charge at max capacity. Regardless of how high the watts are, the ipad should control the amount of charge being received automatically.
